Filter Widget: Different Symbol/Color for Each Selection?
1124
04-05-2024 01:06 PM
ReduceReuseRecycle
Map: https://experience.arcgis.com/experience/6937998752b148658765fcdc72ff0ccb#data_s=id%3AdataSource_2-1...
Does anyone know a way I can change my symbology to have a different color symbol for each filter?
Right now all my symbols are the same, black tear drop. I'd like to have different colors so if more than one filter is selected it'll be easy to differentiate? Can this be down via Web Map?
Thanks!
RickeyFight
MVP Regular Contributor
I believe if you change the symbology in the map using the category field then the filter would be different based on the filter turned on.
RickeyFight
ReduceReuseRecycle
Thanks Rickey, you nailed it.
