Filter List or Table widget in cascade
2655
04-20-2023 10:40 PM
PierreloupDucroix
MVP Regular Contributor
I am trying to filter several lists, or tables in cascade, so that when I select one element in the first list, elements of the second are filtered, and then elements of the third are filtered to...
Let me explain, I have 3 feature classes with relationship classes between them (FC 1 in relationship with FC 2 and FC 2 in relationship with FC 3).
In the table widget or list widget, I can filter the data that are used in the widgets with trigger actions.
As a result, when selecting an element in one list, it will only filter (and select) elements in the second list, but will not cascade the filtering and selection to the third list...
Do you know how to achieve that ?
CEO of MAGIS
RamaniGanason
This seems like the OOTB behavior of most of the widgets. You might need to develop a custom widget that perform cascading selection. I'm in the midst of developing this currently.
LarsElmkær_Chwastek
I'm trying to do the exact same - did you ever find a solution for this?
@RamaniGanason did you ever develop a custom widget for this, and would you be willing to share it? 🙂
RamaniGanason
Did manage to finish it but won't be able to share the widget. Build for a project. Can share the steps required if you have the requirement. 😁
LarsElmkær_Chwastek
Hi @RamaniGanason I completely understand 🙂
But just the steps would also be grately appreciated.
