Field alias not seen in Experience Builder Form
1326
10-14-2024 06:37 AM
PamDeAndrea
Hi I have created a form in Experience Builder and if I choose "Customize" for the fields, it displays the field names and not the aliases for two fields.  How do I get the form to show the aliases and not the field names? When I select use Webmap settings, it shows the alias name for these two fields, but then I lose the capability of adding fields that I have in the web map.
Not sure why the forms whether using customizable or not for the fields does not display the alias.
Shen_Zhang
Hi @PamDeAndrea - Thanks for reporting, could you please share a sample app that reproduces the issue?
Shen Zhang
Laura
by MVP Regular Contributor
The field names also auto pop up in the table widget rather than the aliases.
