Feedback comments on web app maps experience builder
1555
05-08-2023 04:41 AM
NinaGuyot
Hello everyone,
I am trying to build a Web App with the Experience Builder. The goal of the map is that viewers could add pins and write comments where they want in the map (and that others could see these comments). Which widget can I use for that or how could I do it without a widget?
Thank you!
Nina
GaryMorris2
I would use the Edit widget; you will need to make sure that the add geometry function is enabled.  You can set the attribute table have a comments column that they can fill out.  Then configure your pop-up to show that column.
NinaGuyot
Great, im gonna try that. Thank you!
