Feature Template - Prompt for faeture value
327
03-11-2026 11:58 AM
KevinRomans
I am creating some feature templates and sometimes have 3 or 4 fields that I select the "Prompt for feature value". Is there a way to set it up so that when I change the values in the fields they keep those values until I change them? The way it is now if I add a value for a feature, move to another feature then come back to the initial feature I have to update the values again. I know I can set a default value in the template but I was hoping it could be handled in the prompt window. Anybody know if it's possible.
Ke_Xu
by Esri Regular Contributor
Hi @KevinRomans,
Could you provide screenshots indicating which specific feature in ArcGIS Experience Builder is being used?
Ke
