I am trying to use the Text widget to display totals for a field. That works fine for all records in the field using SUM{NAME} but I'd like to separate the totals by records of another field. An example would be a table with NAME and MONEY.
I want to display the total money each person in the NAME field has. Like:
Bob $25
Jane $30
Pedro $40
Also, if there is a blank (no name) in that field, don't show a total.
If you have access to the SQL table you could make a view then bring that view (virtual table) into Experience Builder:
Select NAME, Sum(MONEY) from TABLE group by NAME.
Incredibly easy in SQL. Looking for an answer in Experience Builder as well.
Is there a list of Functions that are available? Seems like it should be easy if I had the correct syntax.
Hi @KelleyCochran,
ArcGIS Experience Builder now supports Arcade. You could use Arcade Dynamic content.
Ke
Can you expand on what version of Experience Builder you're referring to above? v11.5 enterprise does NOT support arcade..
