Expressions in Dynamic Text EB
727
07-11-2025 09:43 AM
KelleyCochran
I am trying to use the Text widget to display totals for a field.  That works fine for all records in the field using SUM{NAME} but I'd like to separate the totals by records of another field.  An example would be a table with NAME and MONEY.
I want to display the total money each person in the NAME field has.  Like:
Bob $25
Jane $30
Pedro $40
Also, if there is a blank (no name) in that field, don't show a total.
DanCopKac
If you have access to the SQL table you could make a view then bring that view (virtual table) into Experience Builder:
Select NAME, Sum(MONEY) from TABLE group by NAME.
Incredibly easy in SQL. Looking for an answer in Experience Builder as well.
KelleyCochran
Is there a list of Functions that are available?  Seems like it should be easy if I had the correct syntax.
Ke_Xu
by Esri Regular Contributor
Hi @KelleyCochran,
ArcGIS Experience Builder now supports Arcade. You could use Arcade Dynamic content.
Ke
ahargreaves_FW
Can you expand on what version of Experience Builder you're referring to above? v11.5 enterprise does NOT support arcade..
