Exporting importing an experience to different environments
991
05-01-2025 06:32 AM
Gurunara
Have an experience built on a DEV environment... when time to deploy to other env's such as QA and PROD, which connect to different ArcGIS servers, is it possible to export an experience and import to new environment? I've had issues with importing an experience from different ArcGIS env's. And I am wondering if I am going to have to recreate an experience when it becomes time to deploy to production... For e.g. if it's not possible is there way to modify the contents of the exported zip file so that they can be imported from different environment..?
JakeSkinner
Esri Esteemed Contributor
Hi @Gurunara,
Check out this toolset.  You can use it to copy an Experience application to another environment.
JakeSkinner
Hi @Gurunara,
