Experience builder tooltips
1672
01-22-2025 09:25 AM
kaander08
Hello,
I noticed that the widget controller has different tooltips (color, font, etc.) than the other widgets. Is there a way to fix this? The first picture is the widget control widget and the second image is a button. All tooltips match the button tooltip, the only tooltip that is different is the widget controller tooltip. See below:
DanielFox1
Hi @kaander08
Just had a look at the Experience Builder and I cannot see any immediate settings from an out of the box experience which would allow you to alter those labels when you hover over the widget. It would seem that this is:
1. By design
2. If you have a Dev Edition you might be able to customise this further.
DanielFox1
Hi @kaander08
1. By design
kaander08
Hi Daniel,
Thanks for your response. I also tried looking into the ArcGIS Online Assistant, and there was not a way I could change it in there. I have tried every work around and there does not seem to be a solution. Hopefully Esri can fix this in the future. It would be nice if they were uniform.
