We've been building a web app in experience builder. The first page is a map with a sidebar with the map layers widget. When previewing the app, the map loads okay (5-10 seconds), but the map layers widget can take up to a minute to load. I've tried to optimise it by switching off all the layers, and saving the web map using the new map viewer. However, it hasn't sped up the load time. Has anyone found a way to speed up the load time? There are approximately 100 layers in the map but they are all switched off. See the attached image. Thank you, Heather.
You and me both. I didn't consider it until I thought to use the browser's dev tools to see if an error was being produced. Everything worked normally then. That's when I considered screen resolution and that one fix solved the issue on three browsers.
I found a possible reason. There are many queries of returnCountOnly that may stuck the Map Layers widget in your app. @HeatherBell @TonghuiMing
Hi, do you still see the slowness? If so, do you have a reproducible app to help us identify the issue?
Hi @JunshanLiu, we no longer use this particular app. One of our analysts has created something custom instead to replace it: https://data.catchmentbasedapproach.org/pages/explore-data. It seems that the screen resolution is helping some of the other users on this thread though, so perhaps someone who is still experiencing the issue can give a reproducible app. Thank you.
