Experience Builder Printing Widget Problems
11683
15
08-03-2022 03:53 AM
MatAzzopardiRWE
Having a few problems with the new printing widget in Experience Builder.
1. Co-ordinate Transformation Error
I have included the printer widget in my webapp and want to give my users the option of printing whether using ESRI's basemaps such as the World Imagery, or for the Ordnance Survey basemaps. I've had difficulty printing to either the World Imagery or GB Cartographic when using different default output spatial references with either WKID 3857 (WGS 1984 Web Mercator auxiliary sphere) or WKID 27700 (OSGB). My datasets can translate to either WGS1984 or OSGB within the webapp, but not on print, so currently I have two printing widgets, one for ESRI using WKID 3857 and one for OS using WKID 27700. As my end users won't fully understand about the two different co-ordinate systems, I'm worried that they may use the incorrect printing widget for whichever basemap and then start showing information in the wrong place. Is there anyway to work at this properly, rather than my work around of having two printing widgets? Any recommendations would be highly appreciated!
2. PDF Font Error
I'm encountering a problem with the PDF/Font after print. On some PDFs, the text is appearing as normal, however on some PDFs the text has altered and doesn't look evenly spaced out correctly. This further causes a problem on saving the PDF and on opening in Adobe Acrobat, the error appears of "Cannot find or create the font 'ArialUnicodeMS'. Some characters may not display or print correctly". On going past this error in Acrobat, then all text displays as POINTS.
In the Font properties of the incorrectly displaying PDF it reads.
ArialUnicodeMS    Type: TrueType(CID)     Encoding: Identity-H     Actual Font: Unknown
In the Font properties of the correctly displaying PDF it reads.
ArialUnicodeMs (Embedded Subset)     Type: TrueType(CID)     Encoding: Identity-H
3. Legend displaying
The legend does not display for me in experience builder at all.
In WebAppBuilder, it is displaying for me.
ShengdiZhang
HI @MelanieNeedle , If the layer is not displayed in the legend, it will not be included in the print legend either. If that's not the case, could you send me your map so I can look into it further?
Shengdi
MelanieNeedle
Thanks for the response!  I took one of the layer lists out of the group to test it out. The surface water layer group has been ungrouped. https://experience.arcgis.com/experience/96b67c718ddb4a829975bf78fa7fe978?draft=true
MelanieNeedle
Hi @ShengdiZhang I am still having issues with EB Print Widget.
https://experience.arcgis.com/experience/e47ee89b76db4ee385e70f8380e2411c?draft=true
I do not have any grouped layers.
Thanks!
ShengdiZhang
Hi @MelanieNeedle ,
Sorry, I missed your earlier comments.
I cannot access the print service in your sample app, so I used the default AGOL print service for testing. Everything works as expected on my end.
When I enable layers in the Map Layers widget, the print output includes all legends correctly.
Could you provide a bit more detail about the issue you encountered and what you were expecting to see?
Shengdi
MelanieNeedle
Thanks for looking into this. @ShengdiZhang Were you not able to access the print service widget?  Screenshot provided to show the error received.
ShengdiZhang
Hi @MelanieNeedle ,
I can access your print service now and reproduce your bug.
However, as I said earlier, the print success if using the default AGOL print service https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/
I think this bug is probably due to something related to your print service.
Shengdi
