Experience Builder measuring tool performance
9876
28
08-16-2024 04:46 AM
Maryse
Some users have reported issues with the Experience Builder measuring tool since the recent update - both the default measuring tool, accessible from the map settings and the measuring tool widget.
It's quite slow to use, freeze often and randomly crash the whole Experience Builder (it was working fine before that).
Is it a known issue ?
Ke_Xu
by Esri Regular Contributor
Hi Maryse,
Does the app crash on AGOL or Portal? Could you help provide a sample app for us to troubleshoot?
Ke
GrantCountyGISSup
I have this issue with our Enterprise Portal, I have had to take the measurement tool off of the web applications.  I did notice for my experience, the Web Map type mattered.  When I opened in Classic the measure tool worked for the Web Map but when I use the new Viewer the measure tool immediately froze when I put the first point down. I have screen shots in my post but no GIF https://community.esri.com/t5/arcgis-enterprise-portal-questions/measurement-tool-won-t-measure-in-x...
ShaneONeill_144
Hi Maryse, I've not been able to recreate the same behaviour - is this in ArcGIS Online or ArcGIS Enterprise? Is this happening for all users? Are any other widgets causing issues?
Wei_Ying
Hi @Maryse ,
Unfortunately we cannot reproduce the issue as you described.The measurement performance looks good to us.And we haven't heard about such cases from other users.  Are you measuring with specific basemap or data? It would help us investigate if you can share a repro app to us. Thank you!
Maryse
Hello, The Experience Builder crashes in ArcGIS Online. The data are in British National Grid and I am using the ESRI Basemaps (the GB one and World Imagery).
I tried to replicate the issue, and it might be related to the volume of data on those specific WebApps ?
The measuring tool runs fine on WebApps with just a couple of layers, but it seems to struggle on WebApps with a larger volume of data (e.g. general project information, water, noise, geology, etc.)
A couple of additional notes:
1-It was working fine on those WebApps before. We've started experiencing issues the past 3-4 weeks.
2-The volume of data hasn't increased drastically.
3-The measuring tool is slow to use, with just 2-3 simple layers from the WebApp being turned on.
(Do I need to open an IT ticket to share a sample app ?)
Thank you!
Wei_Ying
Yes, it would help us to investigate if there is a support ticket with sample app.
Appreciated.
emwing
We are encountering the same issue with the measure tool in Experience Builder on AGOL triggering a crash…but not for all users. For some users clearing the browser crash fixes the problem. I’m trying to find the commonality with the users having issues.
emwing
We have seen a consistent pattern that the measure tool is very memory intensive and pushing some browsers beyond their capacity to cope…particularly is there is complex web map. We’ve had some success thinning down the web map complexity, and having users limit how many browser tabs and desktop applications running. Especially if they are running 16GB of RAM or less.
Wei_Ying
@emwing thanks for your feedback. Would you be able to share your app for us to investigate?
Or submitting a ticket through Esri Support may help us get the repro case. Thank you!
