Experience Builder mapExtraStateProps usecase
1817
02-01-2024 10:32 PM
BhaveshSuthar
Hello everyone in the community!
So I am creating a custom widget using functional component and I need to use the mapExtraStateProps function in my component, I know that in class component I just need to define the function and is internally invoked. But how does this work in functional component?
Thanks for your help in advance.
BhaveshSuthar
I found in the documentation that we can use useSelect similar to useSelector in Redux. How to import useSelect?
QunSun
by Esri Contributor
Hi @BhaveshSuthar , you just need to set Widget.mapExtraStateProps = function(state, props) {}. This is equivalent to class component.
Here is the code snippet.
/** @jsx jsx */
import { React, type AllWidgetProps, type IMState } from 'jimu-core'
import { type IMConfig } from '../config'
export interface ExtraCustomWidgetProps {
export interface WidgetProps extends AllWidgetProps<IMConfig>, ExtraCustomWidgetProps {
const Widget = (props: WidgetProps): React.ReactElement => {
  return (
// define mapExtraStateProps for functional widget
Widget.mapExtraStateProps = (state: IMState, props: AllWidgetProps<IMConfig>): ExtraCustomWidgetProps => {
  return {
export default Widget
