experience builder legend widget turn off layer name
625
12-17-2025 08:36 AM
SarahRijneke
Is it possible to configure the legend widget in the experience builder web designer to only display the layer symbol & description? I see the layer name, the expression name and each of the symbol names displayed in my legend widget and I only need the user to see the symbol name (i.e. $7 flat rate). The current setup displays unnecessary information.
JamesPoeschel
In a normal web map, do you see the same legend?
If so, you can remove that "New expression" subtitle in the web map symbology. There's no way to do that straight in ExB.
Shen_Zhang
It's not possible to do so in ExB at the moment - the content comes from MV legends, so they should look identical.
Shen Zhang
