Map widget not reverting to previous filtered extent
517
12-04-2025 07:33 AM
HareefAkerele
When a user clears selections in the Table widget within ArcGIS Experience Builder, the map widget returns to the default/initial map view instead of reverting to the previous filtered map extent.
To give you a bit more context, there are three filters in use: Division, Master Community, and Slotting Status. When I select the Division filter and then the Master Community filter, the map appropriately zooms to that level of selection. The table is also filtered based on that selection, which is great. However, the issue arises when a record is selected on the table. The map zooms to that selection, but when the record is deselected, the map fails to zoom back to the extent of the Division and Master Community that are still selected. Rather it zooms back to the default view.
The is also reproduced by ESRI team. This behavior does not align with expected functionality and impacts user workflow when working with filtered map data. I want to request from ESRI the functionality that allow map to be filtered by selected or deselected filters.
ClioClark
Hi Hareef,
I would recommend posting this on the ArcGIS Experience Builder Ideas page: https://community.esri.com/t5/arcgis-experience-builder-ideas/idb-p/arcgis-experience-builder-ideas
HareefAkerele
Thank you for this. I have posted it in the link you shared.
