Experience Builder - Label of Layers not showing
9305
14
09-30-2021 04:13 AM
Martin1
I am using Experience Builder 1.5 Developer Edition to create a Web App.
The strange thing is, that in my application the labels of layers are not showing. If I look at the webmap everything is ok, but in the actual application the labels are just not there.
Any idea what could cause that?
Webmap        Application
Jianxia
@Stefan_Thorn, Is the map created using the new Map Viewer? if so, could you please try the map in one of the Instant apps and see if the problem occurs? This would help us narrow down where the problem is.
Stefan_Thorn
Hi @Jianxia. Yes, the map was created with the new Map viewer. Last week, I wanted to reply but was to busy. But today, I saw that the issue is solved. I opened the map and the labels are shown. There is also no issue when I create an Instant app.
Stefan_Thorn
Hi @Jianxia, I have to recall my reply above. with some testing, I first thought the labels are only showing in ExB when a layer is saved as visible in the map (new map viewer) used for the ExB app.
But maybe it is problem when loading the map in the cache. When I open the map and switch on one or more layers, the labels are not shown. after a CTRL-F5, the map reloads and when switch on the layers the labels are visible.
In an instant app this is not an issue.
JohnBickmore
Im having a similar issue with labels in experience builder with a BETA webmap. The labeling shows when I zoom out enough so that the centre of the polygon is in view. The label shows in the centre of the polygon. If I zoom in away from the centre of the polygon I cant see the label anymore. THis behaviour is in the BETA webmap and shows in experience builder as well. Ideally the label should show at the centroid of the portion of a polygon within the map view extent.
Jianxia
@Stefan_Thorn @JohnBickmore - looks like a bug in ExB. Could you help open a case in technical support? Let me know the case number so I will follow up.
