I am really keen to take up Experience Builder but I am struggling to replicate the basic functionality I have used in Dashboards and WebApps.
I have run into the following problems:
Hover text/labels - There is a bug so that labels and hovertext use the raw field name (not the alias) which looks super messy.
Map extents controlling charts - It seems that only one data layer in the map can filter charts. This means that if you have multiple charts with multiple data layers you can only filter one by the map extent.
Hi @KarenHiggins ,
For the second issue
Map extents can be used to filter multiple data layers, but you need to add actions for each layer within one trigger.
Add action for data layer used in chart 1:
Add action for data layer used in chart 2:
Regards,
Shengdi
When I add the first "Extent" trigger, it removes the option to create a second extent trigger.
Hi, you can click the Add action button to create another action for the trigger Extent changes.
Whe I go through this process it only allows the "framework" to be filtered. This works for one layer but if you add a second layer to the map (and a chart using it), it is not filtered.
