Experience Builder - Hide Controls on List Widget
3080
02-10-2022 09:35 AM
GRmapper
Hello,
Is there any way to hide the controls on this list widget when being viewed? The pic was generated while I was in the app.
Thanks in advance,
GR
Tags (1)
jcarlson
In your list widget's settings, you can turn most of these off:
That last one with 4 dots is the "Data Action", which needs to be disabled in the "Action" tab:
- Josh Carlson
Kendall County GIS
jcarlson
The only way to "hide" them is to disable them entirely.
- Josh Carlson
Kendall County GIS
GRmapper
Would that be a total disable by individual widget or at a higher level? Turning off would likely be fine I'm not sure where to do that. Thank you.
jcarlson
- Josh Carlson
Kendall County GIS
GRmapper
Perfect. Thank You!!
