Experience builder - Gauge chart
8507
17
11-17-2023 03:14 AM
ElieRizk2
we are planning to build a dashboard using the ArcGIS experience builder. but we aren't able to find how to create a gauge.
kindly anyone has information on how can reach our target?
DianeFoote
Hi-
I ran into this awhile ago because there isn't a gauge widget in Experience Builder.  What I ended up doing what building the dashboard separately and then embedding it into ExB.  You can see what I did here:  https://experience.arcgis.com/experience/f4c4934c5d7548adabe9c44cf5462393/page/Streamflow-%26-WQ/
Good Luck!
Wei_Ying
The Gauge chart is on the road map of 2024. Please stay tuned.
Wei
DanielleGerlach_HNTB
Hi! Do we know how long it will be until this is included? I am in the process of rebuilding an entire dashboard out of experience builder and in the dashboard app because they don't include the gauges but would much rather keep the EXB. It's a better dashboard. Frustrating that it's taken this long to get that functionality.
Wei_Ying
Hi @DanielleGerlach_HNTB ,
Thanks for your feedback! This gauges chart is planned to in the 2024 June release.
Wei
LorynRader
Hi, I am currently working on Enterprise 11.3 and I have no option for the "Gauge" widget under "Charts". Do you know when the release date is for this on Enterprise? Thank you.
Wei_Ying
Hi @LorynRader Gauge chart is available in Enterprise 11.4
KirstenMason1
Is the number option of a chart also only available in 11.4? I'm using 11.3 and I'm trying to create a dynamic infographic within ExB but I'm struggling to find options.
Dan_kmnh
Decent looking gauge, thank you Esri.
BUT, no way to label the gauge?! REALLY?! I see the settings to adjust the Title and Description elements on the Appearance 'tab'. Did I miss where to actually type a title and description?
Wei_Ying
hi @Dan_kmnh ,
It is a known limitation for gauge chart that it does not have title and description option.
Please use text widget to add on top to chart as a workaround. We will fix this issue next release.
Sorry for the inconvenience and Thanks for your understanding.
