Experience Builder Filter Widget - Unique Values list not populating properly
8200
13
07-21-2022 01:43 PM
RInfante
Hello,
I've just started to have an odd issue with an app I'm building on AGOL's Experience Builder. By 'started' I mean it was working fine last week when I demo'ed it to the client but now it doesn't work anymore.
I have a filter that should allow a user to pick a specific attribute value so they can see only the applicable features in an overlay layer.
My problem is the list of unique values is no longer populating properly on desktop - the pull-down menu shows only one or two values instead of the full list of twenty or thirty it should be showing.
See the screenshot below.
The funny thing is, if I turn on Developer Tools in the Chrome Browser I'm working on (I thought maybe something had broken in the back end), the list then shows all the proper values!
The filter also works properly on the mobile version I'm developing of the same app.
Does anyone know what's going on and what a solution/workaround might be? To recap: this is on a Chrome browser, using AGOL's Experience Builder.
Any help or insight would be much appreciated. Thank you!
TonghuiMing
Hi @Cepero_Eudel
Glad to hear that you've pinpointed the issue. We have come across the distinct + geometry combination conflicts before. It looks like your problem is also caused by the limited advanced query capability of the service.
Same with https://community.esri.com/t5/arcgis-experience-builder-questions/filter-widget-dropdown-empty-when-...
(FYI - per checking, BUG-000161315 does not seem to be the same issue)
Cepero_Eudel
The ESRI representative we contacted said an internal note was added to the Bug with the info as well as the screen shots we share with him.  Thank you
JohnnySun
Any update on this?
I am having similar issue with the unique values list not showing the full list on the Filter widget.
We are under the environment of enterprise 11.2
TonghuiMing
Based on your screenshot, you might have another issue than that of this original post. Refer to the following post for more details
https://community.esri.com/t5/arcgis-experience-builder-questions/query-widget-unique-values/m-p/135...
