Experience Builder Filter Widget Displays Domain Codes Instead of Descriptions
74
yesterday
Evan_OKeefe
I had a complaint that the data filter widget in Experience Builder displays the domain coded value rather than the description. However, in the list widget filter it does display the description, as seen below.
Data Filter WidgetList Widget Filter
 I have found one possible workaround by adding a new field and calculating the description from the domain using Arcade. However, rather than putting in a lot of paperwork for this, and adding to the data update workflow, I would like to find out if someone else has had this issue and if there is a setting that someone knows I am missing.
Thank you so much!
Laura
by MVP Regular Contributor
use unique pre defined values in the filter widget. you can set the label to whatever you choose.
