Experience Builder Export to CSV Disable X Y Columns
8067
16
04-20-2023 11:40 AM
ArianaMo1912
By default when exporting an attribute table in Experience Builder to CSV, X and Y fields are generated automatically for point data.
How can this functionality be disabled? I have columns for the coordinates in the table and do not need any additional data there.
Thank you
KarinAhlén1
I would like to know the same thing. The two extra columns is also mirrored (as there is a diffrent standard in Europe and USA, so x is y and y is x) so it just make it even more confusing for our users.
ArianaMo1912
I assume there has been no solution to disable those?
Elizabeth_Burniston
I even tried creating a Form within the web map and using that for my table but still, the x and y appears. I haven't seen or heard of a solution from Esri. @ShengdiZhang - anything new?
ShengdiZhang
Hi @Elizabeth_Burniston ,
Unfortunately, there is no solution at this time and we are waiting for support from the corresponding team. Please follow the support issue ENH-000159365 for tracking.
Shengdi
ClangDevGuy
Hey @ShengdiZhang, what about being able to change the coordinate system of the x/y points?
ShengdiZhang
Hi @ClangDevGuy ,
There's an existing enhancement in our Support (ENH-000159365) that we're currently waiting on help with the corresponding team.
As for changing the coordinate system, you can update it in your own data. You could upload two similar layers in your app—one for export with a different coordinate system—or create a feature table without coordinates.
Regards,
Shengdi
AstridF
Yes! I hope there is an option to disable GlobalID and Object ID as well as X and Y coordinate columns.
