Experience Builder Export to CSV Disable X Y Columns
8091
16
04-20-2023 11:40 AM
ArianaMo1912
Hello,
By default when exporting an attribute table in Experience Builder to CSV, X and Y fields are generated automatically for point data.
How can this functionality be disabled? I have columns for the coordinates in the table and do not need any additional data there.
Thank you
ShengdiZhang
Hi @ArianaMo1912 ,
Unfortunately, it is now impossible to export point data without including X and Y fields.
Shengdi
ShengdiZhang
Hi @ArianaMo1912 ,
Shengdi
ArianaMo1912
Thank you! Yeah, I asked around and realized it is not an option
Elizabeth_Burniston
@ShengdiZhang - In addition to the X and Y fields, the ObjectID and GlobalID also carry over into my CSV. I have had my colleagues test this both as a public user and a logged in user, and they receive the same result. These fields are not checked on in the 'configure fields' of the table settings. I tried making a view of the feature layer and creating a whole new project, but the results are the same. I have searched the community forums here, to no avail, on possible solutions. Any ideas? Thanks!
btw - this is a feature layer updated in S123.
Jonathan_Molineaux
Hi @ShengdiZhang are there any updates on this bug?
ShengdiZhang
Hi @Jonathan_Molineaux Unfortunately, we are still waiting for support from the corresponding team. I'll keep you posted if there is any progress.
jfischer91
Hi @ShengdiZhang,
I'm also curious if Esri has any timeline to address this issue. For sensitive data where we don't want to release exact coordinates, there's no viable workaround other than publishing a flat table of the same data and using that in all widgets by linking via a common unique identifier. But that does not provide the same UI/UX options as just using the point layer.
MelissaSullivan
Hi @ShengdiZhang, is there any update on being able to remove x/y fields from exported csv's? I tried finding ENH-000159365 but was not able to via search. Is there a URL for the enhancement?
zac_cleanprosperousinstitute
Is esri planning to fix this?  For our project, we want people to download the attribute info, but not the coordinates, since there are privacy concerns with some of the points.  Adding the x and y columns automatically also seems like it would make it really easy for someone to duplicate our map without permission.
KelseyM
Also interested in being able to disable the addition of x y coordinates since we already have it as fields in our data.
