Experience Builder - Embedding apps within a larger app
1932
07-25-2022 08:56 AM
RInfante
Good morning!
So I have a general  (possibly silly) question for anyone who's built large or complex Experience Builder apps.
The project I'm working involves slightly over 20 different maps - the maps are all similar and contain the same layers, except each one has been pre-filtered to show the specific information we want to show for that page (like 20+ pre-configured map views so the users don't have to dig through 20+ layer selections themselves).
I posted a couple of questions last week regarding some issues I was having with some of the layers in the maps - they would not draw properly, or it seemed as if Exp. Builder was having issues connecting to the right layer in the right map.
So, it occurred to me - and here's where I'd like to hear from any past experience anyone might have - that connecting 20+ maps as data sources and having as many section/views (aside from landing, methodology, and 'help' pages) in one single app is maybe pushing Exp. Builder a bit too far (there's been a few 'out of memory' crashes as well).
Would it be better if I created 5 separate Exp. Builder Apps (one for each of the map themes the 20+ maps are organized by) and just embedded those into the larger one (with the landing, help, methodology, etc.)? I assume it'd be more memory-efficient to just call separate apps than to load everything into one, but is it also stable?
Thanks!
jcarlson
You could certainly try that. We do have one or two EB apps that have other apps in an embed.
I would also take a look at the options on the Section / View items. I don't know if this is just a Developer Edition thing, but I am able to tell my sections to use "lazy loading", in which the content for the view is not loaded until I actually switch to that view.
Is it possible to just make these each different pages, instead of views in a section? That would prevent them from loading all at once, and would also give you the opportunity to nicely name each page, so users can save the link to, say your-experience-url/?page=preset4 or whatever name makes sense to you.
- Josh Carlson
Kendall County GIS
DavidColey
MVP Frequent Contributor
I believe I read in the documentation from a few releases ago that 16 map pages was a limit....
- David
jcarlson
I'm at 20 and still going strong! Maybe it would depend on the map's configuration, but 16 doesn't appear to be a limit.
- Josh Carlson
Kendall County GIS
RInfante
Hrmm interesting...thanks for the insight! I am using views instead of pages - and yeah, it's not like I definitively know that that's my issue, I just know I had some maps in these views suddenly unable to read a layer properly in the embedded map when everything seemed ok in AGOL's Map Viewer. I'll check out the loading options as you described.
Thanks again!
