Experience Builder Chart widget: Gauge or donut chart displaying percentage of display value in comparison to maximum value
71
yesterday
Ellie_Linden
I have a visualization in the Dashboard app that I’m trying to convert to Experience Builder. This Dashboard Gauge element displays the sum of one field in relation to a Maximum value, which is the sum of a different field. Then in the “Gauge” pane, the “As percentage” is toggled on, which produces the attached visualization.
I’ve tried replicating this Experience Builder using the “Gauge” and “Donut” variations of the Chart widget without success yet. When trying to use the Gauge chart, I see the “Value format” section allows for Standard, Compact, Scientific, and Engineering, but not Percentage. Also, I'm unable to perform different filtering on data for the display value vs. maximum value, which would be required. When trying to do this with the Donut chart, I’m not able to specify the display value in relation to a different Maximum value. If the Gauge variation of the chart is used in Experience Builder, ideally it would display smooth progress without the need of a meter dial/needle, although that's a lower priority.
Does anyone know if there will be advancements to the Experience Builder Gauge or Donut charts to support this, and/or if there’s another workaround that could work in this case?
