I'm looking for guidance on the widget behaviors - yes I've read the documentation but this is a new widget and I've not gotten a feel for how this works yet.
Experimenting with the new chart widget. I'd like to be able to click on a bar in my chart (i.e. # of bridges with a certain condition classification. I'd then like to have that click populated a list preferably, or filter a table, that shows the selected features from the chart. I don't want values, I want counts. Picture attached.
So If I click on Category 3 on the chart, I want the list to show me the 5 bridges in that category in a list / table. So far, I could only get it to show the single value instead of all 5, not sure why yet.
Thanks in advance!
This should be doable. Add a Message action to Select Data Records in the Framework.
Make sure the trigger/action matches the category field your chart is based on.
Thank you, this helped. However, only half of my categories seem to be working.
First screenshot, I've got categories 2,3, 7, & 9 work and filter the list as expected, as well as the map below. Second screenshot, categories 4,5, & 7 don't work... I find this to be very strange behavior. Turned on the category count labels and they are showing the correct amounts ?!
Hi Kara,
If the situation of the second screenshot happen, that should be a bug. But I cannot reproduce with my data. Can you provide some more details for the steps or do you mind sharing the data?
