Experience Builder, Boundary Map, Select Tool does not open unless page is refreshed
1551
04-07-2024 07:55 PM
SummitMapping
Hello all,
I've built a few Experience Builder Applications and I'm running into an issue. When I use the 'Select Tool' NOT the widget, but within the Map Boundary layer, the selection populates the number selected, but the pop-up box does not show. Although, after I refresh the page, the selection remains and then pop-up dialog box shows up.
In the options section of the Map Boundary "Show pop-up upon feature selection" is enabled.
Any thoughts on getting the pop-up to show without having to refresh the page?
Thanks!
TonghuiMing
Hi @SummitMapping
There is a hint next to the mentioned option stating that the interactive selection of the map would not populate pop-ups, which is the current designed behavior:
TonghuiMing
Hi @SummitMapping
