Experience Builder App issue - Data Action to select records in a table
3353
02-22-2024 04:43 PM
gis_KIWI4
MVP Regular Contributor
Hi Team,
I have run into an issue that I need help with.
I have the utility network trace widget.
Idea is that UN widget selects records in feature layer -> which then selects the records in a standalone table.
I have set up the data action in Map
And this works when I select a record manually.
This DOES NOT work when I run the trace UN Trace widget
It selects the records in the feature layer but nothing in the standalone table.
AiminFan1
Hi there,
I have exact issue which I am interested to know if this is a bug or just enhancement to be done in ExB.
A
gis_KIWI4
@AiminFan1 - I couldn't figure it out. I ended up moving the information in the Electric Device layer.
I also see the new Utility Network widget has a data-action tab maybe it will be possible then.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/utility-network-trace-widget.h...
