Experience Builder Add Data Widget
8388
12
03-02-2023 11:47 AM
WGIMaps
So I have been anxiously awaiting the new release of ArcGIS Online Experience Builder so that I may start migrating some of my apps over with some added functionality. Much to my dismay, the most needed "Add Data" widget does not support KML or KMZ files like the previous version in Web App Builder. Is this in the plan to be supported? The whole purpose of the web apps I build is to put this geospatial data in the hands of people whose GIS user knowledge is limited to Google Earth and similar programs. As much as I hate KMLs and KMZs they are a necessary evil. Please add support for KML and KMZ files to the "Add Data" widget in experience builder.
TianWen
Yes, it can be changed using the tool in Map Layers widget. Hope it helps!
MarianaMilshtein
Hi Tian
Thanks for your reply! I didn't know this option existed.
I'll try this
Mariana
AmyJade
I second that recommendation of a Symbology change in ExB.
Also, I'd like the ability to change the ExB Widget default from "My Content" to "My Organization".
This was suggested above by Tim Albert as well:
"If "Select from Account" is enabled the default search choice is "My content".   Users with only "Viewer" accounts will most likely have nothing listed under "My content".  Previously in Web App Builder it defaulted to "My Organization".   Please either allow the widget default to be set in widget configuration, or default to "My Organization" for non public facing maps.  Having to explain to viewer users that they have to change this setting first to find and add the organization's data, adds an unnecessary layer of complexity to the tool. "
