Expand Map List widget when opening the application
1131
02-03-2023 04:59 AM
JoseSanchez
Hello,
Is there a way to expand the Map List Widget when the application opens?
Thanks
JohnDoroba
You have to add "Expand" to require and function, then create an element/widget object in your script.  Then you have to create an expand object  that calls the element/object you want to expand. Here's an example from a JS API script I wrote for a webapp:
Here's an example from ESRI
https://developers.arcgis.com/javascript/latest/sample-code/widgets-expand/
SanchezNuñez
Hi John,
I am working directly in AGOL. If I understand correctly this feature requires the developers edition.  This feature is available in WAB.
