ExB Enterprise: deleting action on map widget deleting the wrong action BUG?
1340
01-03-2025 05:27 AM
Stefan_Thorn
Update: created a support case: Esri Case #03803038
I am wondering if others also encounter this issue.  I encounter this issue in a client enterprise environment (10.7) as well in our company enterprise (11.1).
Created this ExB for this issue in our Enterprise.
Defined actions on map widget
Record selection changes Action 1: filter Boslaag to list Boslaag
Record selection changes Action 2: filter Lintbegroeiing to list Lintbegroeiing
Record selection changes Action 3: filter parcel <-- wrong action needs to be deleted.
Extent changes Action 4: spatial selection parcel based on map extend, filter to list Kadastraal perceel
Deleting action 3 on map widget
After deleting ‘Record selection changes Action 3’, two actions in Record selection changes remains.
But the ‘Record selection changes Action 1: filter Boslaag to list Boslaag’ has been deleted.
Action 1: filter lintbegroeiing to list Lintbegroeiing
Action 2: filter parcel (which should have been deleted)
When deleting now action 2, actual action 1 is being deleted.
It seems that the action first in the list is deleted instead of the selected action
Stefan_Thorn
Update: esri not able to reproduce this issue.
Workaround: move the action to be deleted to the top of the list and then delete the action.
Laura
by MVP Regular Contributor
Typically  bugs are handles and logged through calling Esri Support.
Stefan_Thorn
I know, and I share that with the community.
Stefan_Thorn
