ExB BUG with in-map Select tool
2279
10-05-2021 05:00 AM
David_Brooks
MVP Regular Contributor
I've noticed that the select tool is pretty buggy in Experience Builder, when selecting a large number of features. I've embedded a video that shows how it doesn't select all features, when zoomed out and selecting a large number, but works fine when zoomed in.
(view in My Videos)
Is anyone else seeing this?
David
..Maps with no limits..
Tags (3)
jcarlson
I've certainly seen behavior like this. I believe there is a limit to the number of features that can be selected. Can you confirm how many points are being selected in the video above? You could add a text widget that shows the COUNT() of the selected features to make it easier.
- Josh Carlson
Kendall County GIS
TonghuiMing
@David_Brooks @jcarlson - This is something we also noticed and we will look into it. Thanks for bringing it up.
RyanRawleigh1
I was wondering if there was an update pertaining to this bug?
TonghuiMing
A previous solution, is to increase the data source page size (by default 100) to a large number;
After the latest AGOL 2023 Oct release, the issue has been resolved so it shouldn't cause any cap issue. Thanks.
