error when login the Exb
943
05-27-2025 05:43 AM
baohuachu7
When click the "login" button, no response.
The browser console is as  attached.
Environment :
     portal:10.6.1
     Exb dev version: 1.17
  OS: windows server 2016s 
Tags (1)
Allen_Zhang
I see CORS(Cross-Origin Resource Sharing) errors in the snapshot, which tell that https://localhost:3001 can't fetch the portal URL's resources.
Maybe the portal admin has forbidden CORS requests?
See:  https://enterprise.arcgis.com/en/portal/latest/administer/windows/restrict-cross-domain-requests-to-...
codethemap
This might help for offline environment:
1. Create self-signed cert on IIS
2. Find and use OpenSSL (find a path of openssl.exe on your local machine)
3. Use OpenSSL to extract the certificate and key (through cmd command)
4. Move certificate files to EB installation server folder: ArcGISExperienceBuilder\server\cert
5. Import certificate into trusted store with CMD -> MMC (ref: https://learn.microsoft.com/en-us/skype-sdk/sdn/articles/installing-the-trusted-root-certificate)
6. Add HTTP response headers for JSAPI folder in IIS
baohuachu7
I have used the same Open SSL  certificate to Exb, IIS(for js SDK and calcite), portal.
It seems the issue is from offline calcite components configuration steps.
I deploy local "calcite" follow this:offline calcite configuration
Wei_Ying
So do you mean you are working on offline environment and seeing this login error?
