Set As Analysis Input not available?
512
06-09-2025 06:58 AM
GISUser74305830
I am not seeing the Set As Analysis Input option for ExB. Here's what I'm trying to do:
  1. Add Data widget - user adds a CSV file of points (Success)
  2. Select widget - user selects a subset of points from this runtime layer (Success)
  3. Analysis widget - this selection is then fed as input into a custom geoprocessing tool to append to a Master point layer (Failure)
Of course, I can append the entire CSV file to the Master layer without issue. I just want the user to be able to use a selected subset instead of the whole thing. Reviewing the Community, it appears the Set As Analysis Input would get me my solution, but I don't see any option to configure it under any widget's Data Action.
I am using Enterprise 11.3.
Wei_Ying
Hi @GISUser74305830 ,
"Set as Analysis input" option is available on Enterprise 11.4 and newer
https://doc.arcgis.com/en/experience-builder/11.4/get-started/whats-new.htm
