Enhancement: Honor "Do Not Show In Legend" Properties from Web Map for TOC
805
06-13-2020 09:48 AM
BlairDeaver3
I noticed that if you choose to hide a layer from the legend in a Web Map the layer still displays in the TOC.  It would be nice if you could hide a layer from both the legend and TOC for display purposes.  Thank you for your consideration.
Cheers,
Blair
DavidMartinez
Hi Blair,
For the map layers widget, you would like to choose which layers to show in the layer list, correct?
David
Bob_Spaulding
It's been nearly two years, but yes, that's something I'd like to be able to do.  Is there a way to do that presently, much as Web App Builder would let you narrow the layer list associated with any particular instance of the layer widget?
