Embed Experience builder app as an iframe in website
13994
22
05-30-2023 04:00 AM
ShiraKellerMandel
I would like to know if it is supported by Esri to Embed Experience builder app in iframes in external websites.
NiklasKöhn
Hi all,
picking this up because I was just made aware of the issue by a customer who needs it.
@Wei_Ying: It's actually not so hard to create your own example. Just create a basic experience with a WebMap in it and see how it behaves in an iFrame.
I did exactly that and the issue is there: Embedding a protected experience in the iFrame gives me an "Item does not exist or is inaccessible" error.
I came up with this workaround: It works for me with a publicly shared Experience that accesses a protected map (screenshots below). This means that the data is still not publicly accessible (assuming the services in the map are also protected), only the outer frame of the application can be loaded. As soon as the application accesses protected resources, it is redirected to the OAuth2 mask, so you basically see nothing of the application without authenticating.
Wei_Ying
Hi @NiklasKöhn ,Thanks for following up.
What edition of ExB are you using? Enterprise or Online?
We should have fixed this issue for AGOL edition in June release for BUG-000168706.
EJSlager_kcgis
I am still having this issue with an ExpB app on the AGOL edition after the June update. I am trying to embed a non-publicly shared ExB into an Enterprise Site (i.e. Hub Basic) using the IFrame card in Enterprise Sites.
To be clear: the ExB app was built on AGOL, the Enterprise Site is deployed on ArcGIS Enterprise.
Wei_Ying
Hi we just release new version in November 2024 ArcGIS Online, can you try again and see if the issue still exist?
EJSlager_kcgis
Yes, I am having the issue after the November update as well.
Wei_Ying
Thanks for confirming. Unfortunately I cannot reproduce the problem you see.
Would you be able to reach out Esri Support (https://support.esri.com/en-us/overview) to provide us a repro case and details? Thank you!
DarraghOSullivan
Jumping in here ... @Wei_Ying you say it is 'applicable' to embed ExB in an iFrame. What does this mean in terms of support and performance? Our app is quite 'heavy' so I'm wondering if it's likely to have speed/responsiveness issues etc? Thanks
Wei_Ying
So far we have not heard performance feedback for embedding ExB app to iFrame. If you have the issue, would you please work with Esri Support to provide a repro case so we can investigate? Thanks a lot.
SStopyak_BruceHarris
We have tried embedding an Experience into an iframe. It breaks the data actions for exporting to CSV JSON and GeoJSON in Edge and Chrome browsers. Still looking for a viable workaround to present the Experience with a custom domain (like you can with Hub).
ShengdiZhang
Hi, the export issue should have been fixed in the recent AGOL update. Can you still reproduce it?
