Editor widget how to copy/paste a shape from another layer
2322
05-22-2024 11:03 AM
SanchezNuñez
Good afternoon,
Is there a way to copy/paste a line from one layer that I am not editing to the layer I am editing?
Ther are moments when instead of drawing a line we could copy/paste another one that already exists in another layer.
Thanks
Laura
by MVP Regular Contributor
JoseSanchez
Tahnk you @Laura
ericsamson_tract
This used to be possible with the smart editor within web appbuilder, but was not ported over. I need this as well. Right now I think the only option is creating a custom widget.
SanchezNuñez
Thank you @ericsamson_tract
I am recommending to use ArcGIS Pro. Editors will drag and drop the editable web map from AGOL to ArcGIS Pro, then they will digitize lines copy/pasting them from another background layer.
Thanks
Bud
Legendary Contributor
As @AlixVezina mentioned in Copy Features for Experience Builder:
Copy and Paste in now available in Experience Builder in ArcGIS Online. It will also be available in Enterprise 12.1 which is targeted for May 2026. You can find it in the Edit widget, when using "Interact with a Map widget" Mode. The option is at the bottom of the Content panel, as part of the Advanced editing tools.
