Edit Widget in Experience Builder fails to load after June 2025 Update
3930
14
07-08-2025 12:21 AM
LindsayRaabe_FPCWA
MVP Regular Contributor
We have found that in some of our Experience Builder webapps, the Edit widget is failing to load up properly after the June 2025 updates have been applied. In troubleshooting the issue, it also seemed to be inconsistent for different users despite all being the same user type and role plus in the same groups.
After trying to recreate the Edit widget from scratch in one Experience Builder, we thought we had fixed it. So we deleted the original, renamed the new one back to "Edit" and , oh wait - nope still not working. Rename to something else, and it works!!
Moving on to the 2nd EB app that I've found with this problem, and I implement the same fix as above and get similar results - 1 works and 1 doesn't where the new one was loaded in side-by-side with the old one.
Anyone else finding issues with their Edit widgets post updates?
Both edit widgets are identical.
Lindsay Raabe
GIS Officer
Forest Products Commission WA
Laura
by MVP Regular Contributor
Mine have all supposedly been working fine.
TianWen
We cannot reproduce the issue. We would be happy to further investigate it if a sample app could be provided. Thanks!
LindsayRaabe_FPCWA
OFFICIAL
If you want to send me usernames, I'm happy to share the apps to you to examine. I think I've got another one that needs to be done still.
Lindsay Raabe
GIS Officer
LindsayRaabe_FPCWA
Looks like it could be a Cookie issue. Had a user try forced refresh and that didn't work, but clearing their Cookies did. Will monitor. Still happy to share if you want to investigate at all as it didn't start happening until after the updates.
Lindsay Raabe
GIS Officer
TianWen
I've sent them to you via Direct Message. Thank you!
ChelseyAiton2
@LindsayRaabe_FPCWA Did clearing the cookies solve the issue? We are experiencing the same thing. It seems very random.
LindsayRaabe_FPCWA
I believe so. I have my browser set to Clear cookies automatically on close. I personally never saw the issues and pretty sure it has cleared it on others machines too. I actually started using this setting to fix cookie issues with Community and other Esri things in the past.
Lindsay Raabe
GIS Officer
WillAnderson
Hi Chelsey - Did you resolve this issue? We are experiencing the same after migrating dozens of apps from Web Appbuilder. Argh.
ChelseyAiton2
For most everyone it seems to have resolved itself, except one user. I'll have to try Lindsay's last suggestion for clearing cookies on certain sites.
