Edit Record widget - how to change default display field?
1866
10-30-2023 02:47 PM
ElizaKronenberger
Hi all,
I am trying to use the Edit Record widget within Experience Builder. I have a related table (called 'ServiceCompleted') and I want the user to be able to select any record to edit the editable field. However, the only way that the Edit Record widget seems to be showing the records is by displaying the date/timestamp code, which I understand is what Esri stores for date/time fields in ArcGIS.
I assumed that the editing tool widget was showing the layer display (or primary display field). I have tried in several ways (within Portal and ArcPro) to change this display field but nothing seems to work. Here are the instructions I followed within Pro: https://pro.arcgis.com/en/pro-app/latest/help/editing/set-the-layer-display-field.htm
Is there any way to change the way the records are displayed within this widget?
Thank you!
gis_KIWI4
MVP Regular Contributor
@ElizaKronenberger - Hi, I believe this can be fixed by adjusting the pop-up of the related table in the webmap displayed within the Experience Builder.
(view in My Videos)
ArmstKP
