Dynamic fields but only with a value in List widget
1379
12-30-2024 10:58 AM
Jeaner
Is it possible to create a list of specific attributes you want to display but only if those attributes have a value? I want users to be able to select any record (so a filter wouldn't work here) and I have about 10 fields that would potentially contain a value. But if any of those fields does not contain a value, I don't want them to see that field in the list. I have looked and looked and can't figure it out. Any suggestions would be super appreciated. I was able to do this in the popups using Arcade in Classic Web Map but it's not working in the new web map or EB. I am also open to other approaches to this. Please help! 🙂
Ke_Xu
by Esri Regular Contributor
Hi @Jeaner,
Experience Builder does not currently support Arcade, it is on the roadmap for 2025.
Ke
MollyWalkner_1
@Ke_Xu is the 2025 roadmap published somewhere?
Ke_Xu
ShengdiZhang
Hi @Jeaner ,
The text widget supports Arcade expressions in the June 2025 AGOL release.
Shengdi
