BUG [V1.17 & AGOL] button link to a Window>Section>View>Table does not respect the (*) fit to data Column sizing, ArcGIS Enterprise, ArcGIS Online
748
06-24-2025 10:13 PM
Labels (2)
FredericPoliart_EsriAU
BUG [V1.17 & AGOL]
Creating a button link to a Window>Section>View>Table does not respect the (*) fit to data Column sizing.
  1. Create an ExP with a Window
  2. On the main page, create a Button
  3. On the Window, create a SECTION with a View1
  4. On the View1, add a TABLE widget
  5. Populate the table widget with layer data, select a few attributes visible.
  6. Now set the Table Options > Column Sizing > (*) Fit to Data
  7. Back in your main Page, select the button and edit the link
    1. Button link to View > Window1 > Section > View1
  8. Save, Publish and test
  9. Open the app, click on the button:  the Column Sizing Fit to Data is not respected.
Bizarrely if you create other views with other tables, then those work OK and "fit to data" works OK.
.. but not the 1st one invoked via a button.
Tags (3)
Shen_Zhang
Hello @FredericPoliart_EsriAU - thanks for reporting, but I wasn't able to reproduce it on AGOL. Here's a sample app created by following your repro steps: https://experience.arcgis.com/experience/c539d7cbb89f4c2b842996af2a45a5a3
Is there anything that I missed?
Shen Zhang
