I have created an experience builder with numerous tabs to provide maps for different variables: See here. My current views navigation is a long list of the separate tabs, but we would like to use a drop-down menu instead to save space. I can't seem to figure out how to do this in the views navigation tool.
Also, is it possible to have multiple drop-down boxes that contain views navigation for groups of variables (e.g., (1) exposures (2) outcomes).
I appreciate any assistance.
Michael
Instead of using the Views Navigation Widget, make links to your view. You can do this with the Button Widget or the Text Widget, either way there is an option to make a link to a view. You will need to do this for every view which will be a bit annoying, but you will have much more control over how to display these links.
If you would like to put them into a dropdown menu, here is a video explaining how to hack a Sidebar Widget to menu. https://community.esri.com/t5/experience-builder-tips-and-tricks/how-to-create-a-dropdown-menu/ta-p/...
Putting a set of links into a set of Card Widgets, then putting the cards into a Widget Controller would also be a nice navigation menu.
Good afternoon! So I'm in the same situation as discussed here, and that video you linked is not available anymore.
Is there another solution content that showcases this method? I essentially would like a drop down menu for a subsection of views within a main sectional view.
The dropdown hack goes something like this.
Hello Jeffrey,
Do you mind providing a little more detail with how to turn the sidebar widget into a dropdown menu. So far all I have created are the individual buttons with links to pages in my app.
Thank you
Here you go.
Hi Jeffrey,
This is great, I appreciate your prompt support. Seems like this will work! Will accept as solution once complete.
Thanks.
