Hi
I see that the November release of ExB has made it possible to add a sub-type group layer as a data source to most of the widgets, however the Analysis widget does not seem to pick up sub-type group layers, is this expected or do I need to do something in the config?
@BenWalker1, the Analysis widget does not yet support Subtype group layers as documented below, the same as the Analysis tool in Map Viewer.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/analysis-widget.htm
Thanks for the quick reply
@BenWalker1, I just updated the release blog with a note saying that Analysis widget does not yet support Subtype group layers. Thanks for letting us know.
