DockEnabled not respected in popup options
2702
05-25-2023 08:03 AM
JeffreyThompson2
MVP Frequent Contributor
I am working in Experience Builder Developer Edition and I am trying to get popups in my map to dock. I am altering the popup options as follows.
jimuMapView.view.popup = {
dockEnabled: true,
dockOptions: {
position: 'bottom-center'
spinnerEnabled: true
console.log(jimuMapView.view.popup)
In the console log, dockEnabled is still set to false, but I can alter the position and spinnerEnabled and those changes will be respected.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
Within the dockOptions object, add a breakpoint that is lower than the width of the screen. Something like this.
dockOptions: {
  position: 'bottom-center',
  breakpoint: {
        width: 544
GIS Developer
Thomas_Fuhrmann
@JeffreyThompson2I have the same problem. Could you find a workaround?
JeffreyThompson2
dockOptions: {
  breakpoint: {
        width: 544
GIS Developer
Thomas_Fuhrmann
@JeffreyThompson2Thanks! I set the breakpoint to a higher level than my actual screen size to automatically enable docking. Now it works.
ChadHarris
I am just getting into Experience Builder after working with WebAppBuilder Dev edition.  I am having trouble finding where this code is in the file structure?  I have an Experience that I built in Experience Builder on my local Dev edition.  I downloaded the code and hosted it on my agency sever.  I can't seem to find where to make the changes you suggest to dock my popup.  Any help you could provide would be greatly appreciated!!
JeffreyThompson2
You can kind of put it in any custom widget. You could potentially even build a no interface, invisible widget just to alter any map settings or css you desire.
GIS Developer
