Displaying static and dynamic total counts from data, is this possible?
1585
02-19-2024 01:13 PM
jzcgis
Hello, I am trying to build an EB based off a currently used dashboard. In the old dashboard, we use indicators to display the total number of features in the current extent. I have many of these indicators and they each are filtered to a field value to show all of our divisions. Since EB is more customizable, I was thinking of showing all of these in the same page next to the map (currently they are all stacked so you have to click on the arrow to see each of them). Is a text widget the way to go here? I was also thinking of doing something like this: "X out of total xt currently in view" where X is the current extent totals for that attribute and XT is the total in record for that attribute. I just don't see the filter option to do this unless it is hidden behind somewhere. It is pretty straightforward in Dashboards.
JenniferAcunto
When selecting the data to be used in your Text widget you have the option of creating a view. That is where you can add a filter and/or sort the data.
Select Data
- Jen
jzcgis
Thank you, I tried doing this but it wasn't letting me choose a view for each individual expression. I was doing it all in the same text widget, not sure if that has anything to do with it.
TBWI
Did you ever find a solution to having static attribute data in the text widget? I would like to have totals that don't change with the view.
