Displaying popup only in Feature Info widget.
15079
21
09-02-2021 11:23 AM
Boyang_Wang
I am using Feature Info widget in my map, so there is no need for popup window on the map. However, if I disable popup in the web map, the content in Feature Info reverts back to default as the content is inherited from the popup I believe. Is there a way to retain my custom popup content to be displayed in Feature Info widget, but at the same time have the popup window on the map disabled?
Thanks.
JamesAmato
Pop-ups must be enabled in Map Viewer for the Feature Info Widget to work. In Experience Builder you can disable pop-ups for a map by clicking on the map in the page tab, and scrolling to the bottom of the contents menu. This will allow data to be fed to the Feature Info Widget with pop-ups disabled.
JamesAmato
HarmondSantos1
Is there a way for this to work in web scenes? I've tried disabling the popups in Experience Builder and selection seems to be disabled even though popups are enabled in the web scene.
ZachBodenner
MVP Regular Contributor
This is a good method if you only have one layer that needs a popup. In my map, I want to feature one layer's popup in the Feature Info widget (and not have that layer's popup appear on the map itself) but I also need other layers to have in-map popups. It seems like a severe limitation to not be able to do this. Do you know a workaround for it?
Happy mapping,
- Zach
Boyang_Wang
Today while I am experimenting in Experience, I found that this seems to be no longer a issue. Now that when you disable the popup for a layer, the layout in Feature Info is still respecting the popup you set for this layer.
ZachBodenner
Yeah, there's been a lot of progress made since I raised that issue!
Happy mapping,
- Zach
Boyang_Wang
Thank you. The disable option in Experience Builder is exactly what I need.
PLadd
Despite this being an old thread, I'm going to try posting my question to it for some guidance.
It seems like I am missing something here. I want the feature info widget to populate when I click on a parcel but I don't also want the popup window to open.  How do I do that?
I’m using Enterprise/ExB 11.3.  I’ve added a feature info widget.  The only way I can get the Feature Info widget to populate like an ID window is to enable “Enable pop-up” on the map widget.  Otherwise, it’ll only work using the select tool, which requires user to take some extra clicking steps.
Below, feature info widget only populates with "Enable pop-up" on map.  As you can see, this is redundant:
But if I disable "Enable pop-up" on the map widget, feature info widget does not populate.
What am I doing wrong?  Thanks.
PLadd
Kudos to ESRI tech support for walking me through to a solution. Using ArcGIS Pro 3.2.1, I needed to republish my web map. It had originally been published at ArcGIS Enterprise 10.9.1 and I am now at 11.3 so republishing got everything up to 11.3 (Experience Builder and now web map). This allowed the feature info widget to populate as a popup window on map click with the actual popup window disabled on the map widget.
Ystad1
Hello, I am interested in the same functionality as @ZachBodenner mentioned earlier in this thread. That is to be able to have multiple layers with pop-ups but only one in the Feature Info Widget and have that pop-up only show up in the Feature Info Widget and not in the map as well. Is there a workaround for this somehow?
