Configuring report widget to generate report for feature selected in a map
191
06-24-2026 05:41 AM
LouiseHarris1
Hi
I am building an ExB project and it contains the Survey123 widget, Map widget and Report widget. When a feature on the map is selected the details are shown in the Survey widget. I have tried to configure the report widget so that a PDF can be generated for a feature selected on the map but I cannot get this to work. The map and Survey use the same data source (hosted feature layer in the map) but to get the report to use my survey and the associated report template I have to connect to a different data source the hosted view layer - form. By doing this it doesn't recognise that a feature has been selected on the map and therefore shows nothing being selected to generate a report for. How do I configure the report widget so it uses my survey report template and generates a report for selected features?
