displaying counts based on an attribute
1426
09-30-2024 11:13 AM
Laura_m_Conner
All,
In experience builder I am creating a map for inspection reports. I want to give the number of how many failed or passed inspection. Using the dynamic text I can display the over all total. Is it posable to do this based on an attribute?
Tags (1)
JasonBOCQUET
hi @Laura_m_Conner  with the text widget and the dynamic option you can select which attribute use to make an expression by using {your_field} if the passed and failed inspection are on two different field.
If they not, you can maybe use the views of the data you call in the text widget you can create a view with only failed inspection; make your expression and in another text widget do the same things but keeping only the passed inspection.
Laura
by MVP Regular Contributor
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/text-widget.htm
The link lists what is available in the statistics and expression tabs. Personally I have created stats in dashboard because it is much easier and brought that dashboard into exb.
JasonBOCQUET
Laura_m_Conner
The data is has one field for pass/fail so I going to use the view approach.
