Did the EBDE Preview Button Go Away?
1177
7
11-14-2025 08:20 AM
ToddTurner2
I was working in Experience Builder Developer Edition 1.18.
Yesterday, the Preview Button was in the builder interface. Today it is not. It's not there for existing projects or brand new ones I create to test. I destroyed my install trying to troubleshoot and fix it.
So, I then did a brand new, clean install of EB Dev Edition 1.19.  I created a new project - the Preview Button is not there either.
I have scoured the change documentation. I don't see anyting about that.
Is anyone else experiencing the same thing?
Is there a way to generate the draft web page manually with URL parameters?
KenBuja
MVP Esteemed Contributor
Are you viewing this in Firefox? There have been reports of some issues with Firefox v145.0
That said, I'm seeing the Preview button on my machine using ExB DE 1.18 in both Firefox and Chrome.
ToddTurner2
Chrome Version 142.0.7444.135 (Official Build) (64-bit)
MichaelVolz
Have you gotten this message in Google Chrome recently?  Did you select either option or just ignore?
I myself am at version 142.0.7444.163
JeffreyThompson2
MVP Frequent Contributor
I suspect you've added some CSS that accidentally hid the button. So check that first.
The URL parameter for the Preview mode is ?draft=true
GIS Developer
City of Arlington, Texas
ToddTurner2
It would seem. But I don't understand how that is possible on a brand new install of 1.19.
Also, when I try a URL like
https://<laptop name>:3001/builder/?id=11&draft=true
It just gives my the same builder screen
No different than
or
https://<laptop name>:3001/builder/?id=11&views=page
I suppose there is a potential massive rabbit hole to consider - yesterday I was in office directly on network;
Today I am remote at home through VPN.
Haven't seen any difference between the two before, but seems like a possiblity, as my EBDE connects to our 11.1 Enterprise Portal
JeffreyThompson2
I think your home set up is the problem, but it's not a VPN issue. Playing around with the screen size simulator in Chrome, the Preview Button disappears at a width under 1160px. Try using your browser tools to zoom out a bit and it should come back.
GIS Developer
ToddTurner2
Well - you're onto something, there.  If I zoom the Chrome browser to 250%, the Preview option shows up in the three dot menu.  Anything less than that and it disappears altogether.
I have, of course, completely cleared the Chrome browser cache, all types, for all time. (several times). I have now played with the screen size simulations, and experimented with the screen size settings for the EB project.
I will say that it is working just fine in Edge at the moment. However, I have never accepted switching browsers as a real solution. I will continue to investigate.
Thanks for putting me on a promising path.
