In 1.7, I use to use this to define a filter on a layer :
But in 1.8, it didn't work. The entity appears in the map. How to fix it ?
Thanks.
Guillaume
Hi @GuillaumeArnaud - this looks like a similar issue with another post - Filter widget does not work in Map
This has been fixed for AGO. For dev editions, go to the following repo:
And then you can follow the instructions to install this 1.8 patch 1.
Let us know if you encounter any other issues after that.
